Hey guys,
What bearings do I need to order for my stroker bottom end? I've got a 258 4 weight crank and 258 rods with ARP bolts? I'm taking my crank in to be manga-fluxed and turned down tomorrow so I'll have to wait to see how much they are going to turn it down but I thought I read here that have to order a mixed set to make everything work.
Dean
Which bearings to order?
"You'll bunk with private Joker. He's silly and he's ignorant but he's got GUTS and guts are enough!"
Re: Which bearings to order?
You need bearings for the 4.0. The main bearings are different from the 258 and the 4.0. The rod bearings are the same. I have found the federal mogul CB960 rod bearings have the small notch in the rod bearings that let oil out to lube the cam and cylinder walls(I have bought 2 sets). Some rod bearings don't have them.
- John
I use the Federal Mogul bearings for the same reason.
I went with the clevite bearings, which didn't have a notch, but I added the notch myself with a dremel.
- Stroker Displacement: 4.5l
Like dwg said, you need 4.0 (242) main bearings. You can use either the 242 or 258 rod bearings. Most stroker crank sets come with bearings so I just bought a set of 4.0 main bearings and used the 258 rod bearings that came with the crank.
4.5L Simple Stroker
* 4.2L crank & rods
* H802CP pistons (18cc dish)
* 9.57:1 SCR / 8.28:1 DCR
* 0.050" Quench
* 62mm TB
* Hot Air Intake
* 2.5" Magnaflow cat and Flowmaster 50
* JBA Header
* 4.2L crank & rods
* 0.050" Quench
* 62mm TB
* Hot Air Intake
* JBA Header
- IH 392
The '87-'90 4.0's use the same main sets as the 258's, '91 and later 4.0's use a different set.
OOPS, yeah I forgot that. Good catch.IH 392 wrote:The '87-'90 4.0's use the same main sets as the 258's, '91 and later 4.0's use a different set.
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot], Semrush [Bot] and 2 guests
