Valve Cover
nickjc13
Valve Cover
Is there a company out there that makes a valve cover for my stroker that says 4.6?
nickjc13
Re: Valve Cover
Does anyone know anywhere im just trying to be different or is there aftermarket ones?
Re: Valve Cover
I thought I saw one someplace, but after a quick look yesterday I didn't find it. I did find some at Quadratech that has "4.0" on them, but no 4.6.
nickjc13
Re: Valve Cover
That sucks because I know when you open my hood it looks boring and you would never tell its anything different
ARH
Re: Valve Cover
Does it even matter?
'86 XJ - 150/AX5/207 - RIP
'91 XJ - 242/AW4/242 - RIP
'88 XJ - 242/BA10/231
'93 ZJ - 318/46RH/242
nickjc13
Re: Valve Cover
I mean I put all this money into it why not make it look cool ya know.
- RAPTORFAN85
- Plechtan
- Vehicle Model: Comanche
Re: Valve Cover
I( think some guy on Ebay is selling 4.6 stickers
Peter Lechtanski
Re: Valve Cover
I wouldn't trust vinyl on a valve cover (stickers).
I had mine powder coated blue a while ago and it has held up well.
- Mgardiner1
Re: Valve Cover
Have a machine shop use a flow jet to cut one out of steel or aluminum. Grind the raised parts of the valve cover down a little and then either rivet it or epoxy it to the valve cover.
nickjc13
Re: Valve Cover
I just thought it would be different.
Re: Valve Cover
It would be neat. I have been thinking about cutting some out of aluminum on the router. Don't know what epoxy to use though. Thought about JB weld but that rusts.
- IH 392
Re: Valve Cover
Think of it as "Stealth!" , that's what I'm going for on mine, right down to the bar code sticker on the valve cover!nickjc13 wrote:That sucks because I know when you open my hood it looks boring and you would never tell its anything different
Re: Valve Cover
If someone is analyzing under your hood I think stealth just walked out the door because there would be a reason for them to look under the hood.
- Mgardiner1
Re: Valve Cover
It'd be a sleeper! if they are lookin under the hood, you can blame it on the "hollowed out cat" or "flow master muffler"
Users browsing this forum: Bing [Bot], Semrush [Bot] and 1 guest
