Just got a set of Clevite rod bearings. There is no hole at the parting line for the oil squirters! I will be adding a passage in mine.
I have a 2000 model year engine, and the stock bearings had the hole.
Best I can tell is they are for oiling the cam.
Just a heads up if it has not been covered.
Check your rod bearings!
- TurboTom
1979 AMC Spirit
Building a Turbo 2.5
I am not very smart!
1979 AMC Spirit
Re: Check your rod bearings!
The 2 sets of federal mogul bearings I bought have the holes. (CP960)
Yeah, its been covered.
- Mgardiner1
The older clevite rod bearings that i think were made in brazil, had the oiling holes in them, the USA made bearings did not. (or do i have that backwards???) Either way, Chris and I both had to notch our bearings out ourselves.
- Heck
I had to notch mine.
I NEED MORE TORQUE!
'03 Rubicon w/4.6: kb944 pistons, late 70's 4 weight crank, Mopar P4529228ab cam, 240 dur./.430 lift, barely polished head. First fire 11/14/08, no mechanical issues so far.
Users browsing this forum: Bing [Bot], Google [Bot] and 8 guests
