4.6 renix 1, 3,and 6 have no spark
jbxx
Vehicle Year: 1986
Vehicle Model: CJ7
Re: 4.6 renix 1, 3,and 6 have no spark
Post by jbxx »
You did remember to reattach the ground strap from the block to the firewall?
92tank
Stroker Displacement: 4.5
Post by 92tank »
are you sure you have the right cap and rotor i know the newer ones have have different cap and rotors
Could the distributor be work enough to move the rotor too far away from the non firing plugs?
racing89
Stroker Displacement: 306 ci
Vehicle Model: comanche
Post by racing89 »
By chance did you put the wrong flywheel on? A 91-97 flywheel on a 87-90 renix will cause the exact symtoms you have.(Been there. Done that)
justjerald
Post by justjerald »
racing89 wrote:By chance did you put the wrong flywheel on? A 91-97 flywheel on a 87-90 renix will cause the exact symtoms you have.(Been there. Done that)
Yes came off of my 89 renix block I used not to mention it wasn't doing any of this when I spun the bearing the only problem I had be for was it would cut off while I was driving sometimes so I replaced the harness and that problem went away
justjerald
91JeepMJ wrote:Make sure your distributor is properly indexed and if it's an automatic make sure you didn't damage the flex plate when installing the engine.
I know its 2 years later but that was the issue!
cruiser54
Post by cruiser54 »
Which was it?
www.cruiser54.com
justjerald
cruiser54 wrote:Which was it?
The flex plate
cruiser54
Post by cruiser54 »
Damaged or wrong one?
www.cruiser54.com
justjerald
cruiser54 wrote:Damaged or wrong one?
Damaged nothing visable
Now im having a similar problem
jonb8
Post by jonb8 »
I just saw this and it's old but I bought a jeep that wouldn't start after motor swap. It was only firing on 2 cyl and it ended up being a renix flywheel on a HO motor.. The PO swapped a renix block in and didn't change the flywheel. It had me scratching my head for some time....LOL
justjerald
jonb8 wrote:I just saw this and it's old but I bought a jeep that wouldn't start after motor swap. It was only firing on 2 cyl and it ended up being a renix flywheel on a HO motor.. The PO swapped a renix block in and didn't change the flywheel. It had me scratching my head for some time....LOL
Yea it sucks when spend a bunch of money on parts and then You find out your one tooth off on your distributor
cruiser54
Post by cruiser54 »
Are you serious? Bummer.
See Posts 12 and 13 in my link below.
www.cruiser54.com
