4.7 stroker 99 wj- off idle stumble
jeepman
Vehicle Year: 1989
Vehicle Model: MJ
Re: 4.7 stroker 99 wj- off idle stumble
Post by jeepman »
Your Creating BS and Have you actually metered a Factory Fuel system the pressure drops off as The RPM'S go UP so it is LEAN at WOT...
Sorry I am not a person who creates false DATA...
Nothing is exact and my MPG is based on my ACTUAL FUEL CONSUMPTION since you can't read english...
If your "WORD" was correct I would not make it 200 miles on my 22.5G tank and I would have clouds of smoke out the tailpipe but again THAT IS NOT THE CASE which means your WRONG...
Threatening to ban me is a Cowardly way to go because someone does not agree with you, NIce Moderator Job your doing I am sure your proud...
Good luck
:cheers:
jeepman wrote:Your Creating BS and Have you actually metered a Factory Fuel system the pressure drops off as The RPM'S go UP so it is LEAN at WOT...
Yes I have, and no it doesn't drop off unless you have a faulty pump. Fuel pressure stays constant and in WOT it will go rich.
Its not that I don't agree with you its that you are just plain wrong on nearly everything you have said.
Closing thread as this is becoming a fight and not helpful.. to each thier own..
For future readers, please take into account the words of many more than the words of the few.
Locked
