Broken Stroker, Crank end play is 1/8" out of spec. Help
Re: Broken Stroker, Crank end play is 1/8" out of spec. Hel
I wonder if the crank was out of spec...thrust bearing surface too wide. I have read that some of the scat cranks have been out of spec (bearing surfaces).
DaemonForce
Stroker Displacement: 4.7L Super
Vehicle Year: 1983
Vehicle Make: American
Vehicle Model: Eagle
Post by DaemonForce »
That crank is definitely out of spec. Next time pull one from an AMC.
   ,__,_____,__,       ~A-M-C YA!
//___}/,_ll,_\__\,_____
,l_/¯\_l__ll__l__/¯\(¤≡¤)
   (o))o))        (o))o))
Phman9
Post by Phman9 »
My first 4.6 build was done by western engine supply. I got it back with the lower and upper end assembled. I did not see the thrust surface on my first build. New crank and bearings are in. New engine sounds amazing. For sale! 2001XJ Limited 4.6 stoker.
