Stumble when cold
- Vehicle Model: cherokee
Re: Stumble when cold
Runs a lot better now with the new injectors . Next question I have is I put a accel coil in should my plugs be gapped bigger than stock seems like I am getting a knock under load that wasn't there before coil ?
- Vehicle Model: xj
That seems weird to get 'knock' with just a coil change. I would retry the stock coil and see if the knock goes away.
If I gap bigger than stock it seems to run worse and stumble.
Knock or ping?
I to would put the stock back in and see if it is still there. Then try the accel again and possibly reset the PCM.
Ping mostly underpaid .uphill or rite before a downshift . Will try it this weekend . Trying to work out all the bugs on jeep . Seems like one clears another starts . Guess its that jeep thing
