bored out throttlebody?
Re: bored out throttlebody?
Post by John »
http://www.jeepforum.com/forum/showthread.php?t=502977 Sorry about that, The aging process does strange things sometimes.
Sighman
Post by Sighman »
Thanks everyone, I did smooth them out but I didn't bevel them to the extent of the pictures. I'll pull it this weekend and see what happens. Once again thanks!!
:cheers:
rradford9
Stroker Displacement: 4.5l
Post by rradford9 »
Be sure to let us know if that fixes it. I'm battling a similar whistle out of my 62 mm bored TB. I very lightly touched up the sharp edges with my dremmel, but didn't take off anywhere near the amount from the write-up. I still have the whistle, so I'm looking for a solution...
4.5L Simple Stroker
* 4.2L crank & rods
* H802CP pistons (18cc dish)
* 9.57:1 SCR / 8.28:1 DCR
* 0.050" Quench
* 62mm TB
* Hot Air Intake
* 2.5" Magnaflow cat and Flowmaster 50
* JBA Header
Sighman
Post by Sighman »
That did indeed fix it. I didn't go deep enough the first time and it still whistled slightly. Took it back off and went deeper and the whistle is completely gone now!
:banana: :banana: :banana:
Post by John »
Good man. I get a failing grade and you get rid of the whistle.
Dirtweazle
Post by Dirtweazle »
Just an FYI on this thread:
If you bore to 60mm there is no need for a new flutterby....... Works fine on mine. :hrhr:
Troy "WeaZle" McCarty
2K XJ 4.6 (Go Slow)
88 Raceco Class 10 2175cc (Go Fast)
07 Avia 6877 size 12 (Go Pedestrian)
rradford9
Post by rradford9 »
Beveling the port eliminated my whistle too. Thanks for posting the writeup! I ended up beveling the top port above the butterfly a little bit too b/c I blew compressed air over it to clean off any metal flakes and got a slight whistle.
4.5L Simple Stroker
* 4.2L crank & rods
* 0.050" Quench
* 62mm TB
* Hot Air Intake
* JBA Header
