I was talking to Haltec about using one of their "Interceptor" units on a Jeep. It is kind of like a programable Map sensor, but it also can change ignition timing. You cut the wires from the CPS and the Map sensor and splice the unit in. You can then program new timing and fuel corrections with your laptop.
They wanted to know the Construction of the trigger wheel for the CPS. I believe on the ODB 1 and 2 you have 4 slots for each cylinder, the slots are 10 deg in width and then have a solid piece for another 10 deg. so 20 deg from the start of the first slot to the start of the second slot, same pattern for slots 2,3,4 than a 2 slot space ( 40 deg) until the start of the next cylinder. They were also looking for a relaionship to of the slots to TDC.
On the Renix you have 20 slots per cylinder, then a space. it would make sense for the space to be 4 teeth wide ( 72 tooth wheel) but i need sombody who has a flywheel lying around to measure the space and see how many teeth it is equivelent to. I was also looking for the relationship to TDC. I have attached some paged from the shop manual for reference.
Need some CPS info
- Plechtan
- Vehicle Model: Comanche
Need some CPS info
Peter Lechtanski
- Muad'Dib
Re: Need some CPS info
I have a renix flywheel in my garage at home... ill measure it tonight when i get off work.
