Advancing the timing on a OBD 1 engine
Has anyone tried advancing initial timing by moving the crank sensor ?
While I have to admit to not looking to closely. Could the mounting holes for the sensor be elongated a bit. Thus moving the sensor counterclockwise. Might be worth a few degrees or so.
yuppiexj
Re: Advancing the timing on a OBD 1 engine
Post by yuppiexj »
Yes covered here (short version is 2 degrees or so)
viewtopic.php?f=5&t=744&start=0
