With a 1.6 rocker, P5249464 springs, and crane 753901 cam I calculate my lifter load to be 390.72# change that to 1.7 rocker and I get 415.14# HOWEVER I read a bit more and come up on this;
"The actual load on the lifter foot is the sum of the static spring pressure, the frictional loading in the valve train, and the inertial loading of the mass of the valve train."
Anyone mind helping deciphering this http://www.eng.wayne.edu/page.php?id=758
Lifter Load
Re: Lifter Load
It shouldn't be that much. With 270#/ inch spring rate and 120# installed...To calculate your spring rate:
Installed # + (lift x spring rate)=? For example if you had a .500 lift cam using the mopar springs... 120+(270x.500)=? Multiply .500x270=135 So... 120+135=255# at max lift.
There is no way I could even try to figure out that page that you listed
cavaliers1323
Re: Lifter Load
The formula you supplied is for open pressure, the lift on the cam I mentioned is 0.46" which gives me 244.2# open. The formula for lifter load is lifted load= open pressure x rocker ratio. With a 1.6:1 that's 390.72#, with a 1.7:1 that's 415.14# Please double check my math, but I believe it to be correct.
I guess my my question is, are my numbers accurate or do I need to equate things like ramp, mass, speed, etc? Making my number way off.
cavaliers1323
Users browsing this forum: Ahrefs [Bot] and 8 guests
