I didn't find Jeep Strokers Forum until I started my build, but I got most of my info from Dino's website. I've got a 93 YJ, it used to have a 2.5 5 spd and I installed a 4.0 and AW4 out of a 96 XJ into it last summer. Do to all the teeth getting ground off the cam and dist gear from a faulty oil pump I'm building a 4.6 ,so now I have a couple of questions for the stroker experts.
1. I've got a set of Borla 3 into 1 headers, like whats on the 01? up jeeps. What is the best way to route the pipes? My idea is to run 2-2" pipes down to in front of the oil pan and run them into a 3" pipe and then back to my (no cat) 50 series Flowmaster and then run 2.5" out the back. Any comments or suggestions?
2. Is the Firepower ignition kit worth buying from Performance Distributors? http://www.performancedistributors.com/index.html
3. Will the 4.0 flywheel work on a 4 counter weight 4.2 crank? Will the timing marks be in the right location?
4. What is the best/cost effective route to go on the ECM electronics? I bought a Jet stage 2 piggyback chip, but from what I've read I've probably wasted my money, except for the 185* thermo. Any comments or suggestions?
Getting Ready to install my 4.6L, Few Q's
YJason
Re: Getting Ready to install my 4.6L, Few Q's
Here are my answers to your questions:
1. Sounds like a good idea.
2. No. Don't waste your money on it. Just buy a good quality set of plug wires and use the stock plugs.
3. Yes. I used my original flywheel on my stroker and it's fine.
4. Keep the stock '93 PCM and don't bother with the JET Stage 2. I had one for many years but then it began to malfunction and caused the rev limiter to cut in at 4500rpm. After I removed it the rev limiter was back to the normal 5200rpm, the engine felt livelier, and I gained 4-9lbft on the dyno from 1500-3800rpm, so I'd say the JET chip is definitely a waste of money. Just keep the JET 180* t'stat.
