Fel-pro 530sd
Jeepinscott
Fel-pro 530sd
Post by Jeepinscott »
Anyone know the thickness of it?
Anyone using it?
I ran one on my last motor, but it was a stocker and it held up fine, just need to know how thick.
ajmorell
Vehicle Model: ZJ
Re: Fel-pro 530sd
Post by ajmorell »
Dunno but it's what I bought and intend on using with my stroker.
-Andy-
MichiganTech Mechanical Engineering
BSME '09
MSME '10
Re: Fel-pro 530sd
.051" Its just a stock replacement gasket.
crazygogo
Stroker Displacement: 242 + .30 over
Vehicle Year: 2002
Vehicle Model: wj
Re: Fel-pro 530sd
Post by crazygogo »
is anyone using this head gasket on there engines? and if so do you approve or disapprove of it?
PseudoSport
Stroker Displacement: 4.0L Turbo
Vehicle Year: 1995
Re: Fel-pro 530sd
Post by PseudoSport »
Used it on a turbo 4.0L and its nothing special, just a stock style gasket. Ended up blowing it above 12 psi so we went with Victor Reinz MLS gasket and have been fine up to 16+ psi. With a stroker any style should be fine and I’d focus more on its thickness and how it effects your quench.
GRM Challenge 1995 2WD Cheorkee, 2,780lbs, 240k 4.0L, 50 trim T3/T4 turbo, MS1 EFI, 36lbs injectors, -2.5 degrees camber, Ford 8.8 3.73 w/LSD, 274 whp/322wtq, 12.98@100mph 1/4 mile
http://www.Facebook.com/JeepXJR
1982 AMC Spirit - Turbo 4.0L, 60 trim T3/T4, MS1 EFI
Torqsplit
Re: Fel-pro 530sd
Post by Torqsplit »
One thing to consider is the bore-size if using a standard replacement gasket in "0"-deck setups. There's potential for piston interference with the 3.875" gasket. Looks like the 530SD is spec'd @ 4.00 so you good there. Apparently PseudoSport pushed one pretty far before having any trouble, so I'd feel pretty confident with it! Good Luck with your build :cheers:
