the_wrench116
Posts: 124 Joined: April 25th, 2009, 3:59 pm
Post
by the_wrench116 » July 5th, 2009, 1:18 pm
hey i have a 91 block a 12cw crank and a set of 4.0L rods a 68-232-4 comp cams bump stick and a 91 head assembled main and rod bearings.
still need lifters, timing set, injectors,head gasket, ARP studs, pistons ( dish size? looking to run 9.5:1+-.25 static)
what do i need to get this thing together did i miss any thing?????
i know i will need to have my block bored at least .030 may be .060 as the #1 top piston ring broke and wore a BIG grove in the bore.
Plechtan
Posts: 667 Joined: August 28th, 2008, 9:00 am
Post
by Plechtan » July 5th, 2009, 3:42 pm
91 head? That's not an HO is it? I would see if you could get a later head and intake. look at the recipies and FAQ to see where to go. If you look through all of tha and still have questions people on the forum will be happy to answer them.
Peter Lechtanski
Posts: 1506 Joined: January 8th, 2008, 10:55 am
Post
by Muad'Dib » July 5th, 2009, 4:06 pm
91-95 is HO. Casting # 7120.
the_wrench116
Post
by the_wrench116 » July 5th, 2009, 4:23 pm
yes its a HO head and block sorry didnt think to mention it
ajmorell
Posts: 81 Joined: March 16th, 2009, 11:49 am
Vehicle Model: ZJ
Post
by ajmorell » July 5th, 2009, 5:31 pm
With the 4.0 rods you are looking at expensive forged pistons, KB's or Hesco's most likely.
-Andy-
Michigan Tech Mechanical Engineering
BSME '09
MSME '10
the_wrench116
Post
by the_wrench116 » July 6th, 2009, 9:41 pm
are they the only ones readily available? and are they reliable? how many of you have them an have put 75k+ miles on them.
ajmorell
Vehicle Model: ZJ
Post
by ajmorell » July 7th, 2009, 5:28 pm
the_wrench116 wrote: are they the only ones readily available? and are they reliable? how many of you have them an have put 75k+ miles on them.
AFAIK the only pistons available for use with the 4.0 rods are forged. Aside from being a bit noisy at startup forged pistons are significantly better than cast IMO.
-Andy-
BSME '09
MSME '10
the_wrench116
Post
by the_wrench116 » July 7th, 2009, 6:43 pm
AFAIK??? whats this mean?
need forged pistons to run boost
Posts: 693 Joined: February 17th, 2008, 10:45 pm
Post
by Flash » July 7th, 2009, 9:56 pm
the_wrench116 wrote: AFAIK??? whats this mean?
As Far As I Know =AFAIK
the_wrench116
Post
by the_wrench116 » July 8th, 2009, 8:55 pm
got an octopus manifold(99+) complete. from flebay 150 shipped did i do good?
Posts: 1353 Joined: February 13th, 2008, 5:33 pm
Post
by gradon » July 8th, 2009, 9:41 pm
I can get them bare for $25.47+tax at my local JY, probably 90-100 w/ tb and fuel rail. $75-100 seems to be the norm on the forums and on ebay.
