weird dizzy set ups
the_wrench116
weird dizzy set ups
Post by the_wrench116 »
has any one else been able to find a dizzy that is driven off the front of the cam through the cover? i saw one once a while back. could have been a one off or a prototype cant remember where for the life of me. :doh: might solve the billit roller gear problems.
SIXPAK
Stroker Displacement: 280
Re: weird dizzy set ups
Post by SIXPAK »
You could use a remote dist set-up like the jesel unit but of course you would have to modify. But remember, you would have to also incorporate an external oil pump drive off the crank or cam also.
Plechtan
Post by Plechtan »
Jessel does make a distributor that works with yheir belt drive setup, but I don' think they have anything for a 6 cylinder. You might be better off using the 2000 and up coil pack setup or a coil per plug setup.
Peter Lechtanski
the_wrench116
thanks guys coudnt come up with the name but knew i would dave to run either a dry sump or at the very least an external oil pump. might do somthing with a 95 zj or xj with a turbo front mount and all wheel drive. could be fun to rally at the very least. a guy can dream :slobber:
