Junkyard EFI swap, 4.0 flywheel help
EFIeagle
Vehicle Year: 1983
Vehicle Make: AMC
Vehicle Model: Eagle
Post by EFIeagle »
I'm doing a junkyard EFI swap into my 83 Eagle wagon, keeping the .030 overbored 4.2, also using a 4.0 head, and ax15 transmission. I wanted to save some money and figured it would be more worthwhile to just swap an ax 15 in and use the sltock location for the cps, the bellhousing. The problem is, I'm sure the 4.0 flywheel is notched accordingly, and I'm not sure if there's a certain way I need to install it, since I'm using a stock bellhousing mounted sensor, instead of paying 300 dollars for a crank damper. Do I need to have the crank lined up in a certain way before bolting on the flywheel so the sensor reads it correctly?
eliv1
Re: Junkyard EFI swap, 4.0 flywheel help
Post by eliv1 »
The flywheel can only go in one way.
Vehicle Year: 1980
Vehicle Make: AMC
Vehicle Model: Spirit
Post by amcinstaller »
are you also on eaglenest?
EFIeagle
Vehicle Year: 1983
Vehicle Make: AMC
Post by EFIeagle »
Yeah, I've seen you on there as well.
Jeep-Power
Stroker Displacement: 4.3
Vehicle Year: 1984
Vehicle Make: AMC/Jeep
Vehicle Model: CJ-7
Post by Jeep-Power »
eliv1 wrote:The flywheel can only go in one way.
OK-- so how do we ensure it goes on there correctly-- I'm thinking this is covered in the stroker section, as a stroker utilized the 4.0 flywheel on a 4.2 crank.
Let's search...
The bolt holes in the flywheel will only line up with the bolt holes in the crank one way.
Jeep-Power
Vehicle Year: 1984
Vehicle Model: CJ-7
:doh: I've had my flywheel off more time that I can remember. I guess I forgot about that.. :oops:
thanks!
EFIeagle
Vehicle Year: 1983
Vehicle Make: AMC
Post by EFIeagle »
thanks guys!
