258 head
billy_bob
Learning to use the board
Vehicle Year: 1994
258 head
Post by billy_bob »
My question is, is the head from the 4.0 interchangeable with the head on the 258?
90 block, 94 7120 head and rods, IC944 .060 21cc, comp 68-239-4 and of course the 258 crank. my first full build and i did pretty damn good
Re: 258 head
Post by Flash »
billy_bob wrote:My question is, is the head from the 4.0 interchangeable with the head on the 258?
Start reading in this section, you will learn a lot.
http://www.jeepstrokers.com/forum/viewforum.php?f=6
It will work but its not as simple as swapping heads
By the way Welcome aboard :cheers:
Plechtan
Re: 258 head
Post by Plechtan »
ist it really necessaary to fill the holes in the head? their are no holes on the block and the gasket should seal it.
Peter Lechtanski
Vehicle Year: 1980
Vehicle Make: AMC
Vehicle Model: Spirit
Re: 258 head
Post by amcinstaller »
i always wondered that too...
Plechtan
Re: 258 head
Post by Plechtan »
Hesco sells its head for both applications
Peter Lechtanski
SIXPAK
Stroker Displacement: 280
Re: 258 head
Post by SIXPAK »
Back in 1989 I installed a 87-90 4.0 head on my 1973 258 and only used a 4.0 head gasket/ No leaks what so ever. Was I lucky, maybe so. But before I was going to do all the plugging that is now comonly done I was determined to at least try it first and waste a head gasket if need be. Broke the crank in that motor and made my first stroker mid july 1990.
5-90
Re: 258 head
Post by 5-90 »
Note that two different sizes of cylinder head screw were used in the 258ci - one was threaded 7/16"-14, and the other 1/2"-13. The 242ci head accepts a 1/2"-13 screw.
If you're putting a 242ci head on an earlier 258ci block (should be 7/16" screw,) you'll need to use 7/16" screws and have sleeves made to positively locate the cylinder head when you bolt it down. However, the later 258ci tended to use the 1/2" screws, meaning you can drop the head right on.
Apart from that - and the coolant passages - all of the AMC six heads will swap readily, provided the rocker arm mounts are the same (the shaft-mounted rockers tend to oil through the shaft, while the pedestal-mounted rockers tend to oil through the pushrods. Oiling shaft-oiled pushrods through the pushrods is going to cause you some significant trouble...)
Re: 258 head
5-90 wrote:Note that two different sizes of cylinder head screw were used in the 258ci - one was threaded 7/16"-14, and the other 1/2"-13. The 242ci head accepts a 1/2"-13 screw.
Only a couple of years of 258 in the early eighty's used the 7/16 head bolts, of all the AMC sixes I've ever messed with only one of them has the 7/16 bolts.
billy_bob
Vehicle Year: 1994
Re: 258 head
Post by billy_bob »
i was wondering how a 258 head works on the 4.6 stroker?
Vehicle Year: 1980
Vehicle Make: AMC
Re: 258 head
do you maintain good speed turning 90 degrees? haha :D anyway, the ports on the 4.0 HO heads and newer have a more gradual bend into the chamber as compared to the 90 degree bend on the 4.2 head.
coas
Re: 258 head
Post by coas »
SIXPAK wrote:Back in 1989 I installed a 87-90 4.0 head on my 1973 258 and only used a 4.0 head gasket/ No leaks what so ever. Was I lucky, maybe so. But before I was going to do all the plugging that is now comonly done I was determined to at least try it first and waste a head gasket if need be. Broke the crank in that motor and made my first stroker mid july 1990.
The early 258/232 have the block shape straight under the water jackets, just like the 4.0L block and not like the newer 258.
Newer 258 block
4.0L (rradford9 pic)
5-90
Re: 258 head
Post by 5-90 »
Do you happen to recall which ones, so I can update my notes?
