stock valve spring specs.
I got these stock spring specs from alldatapro.com. Installed height 79lb/[email protected] Open 218lb/[email protected]. That makes the valve lift .424 (1.216-1.64=.424). Doing the calculations for spring pressure would make the stock springs 327lbs/in. Spring rate x max valve lift ( 327x.424=138.648 rounded up would be 139 ) plus closed spring pressure ( 79+139=218) the stock spring rate 218 @ 1.216. So the stock spring pressure is 327lbs/in. Just some info when looking into replacing springs for higher lift cams.
- Shark
Re: stock valve spring specs.
thanks, that should come in handy later on.
'95 XJ 4door 4.0 aw4 2" 31's
Lunati has some valve springs part # 73084 O.D. 1.450 / I.D. 1.080 270lbs/in. That would be 101.5lbs @ installed hieght @ 1.700 and 236lbs at .500 lift. Max lift .560 . These may be easier on cam lobes. Any comments/suggestions????
jeepinwi
- Learning to use the board
How can a spring with less pressure be rated for more lift?dwg86 wrote:Lunati has some valve springs part # 73084 O.D. 1.450 / I.D. 1.080 270lbs/in. That would be 101.5lbs @ installed hieght @ 1.700 and 236lbs at .500 lift. Max lift .560 . These may be easier on cam lobes. Any comments/suggestions????
99 Cherokee SE - 2 door, 4x4, 4.6L stroker, 5 speed, 8.25 rear, 60mm TB, stock exhaust
- Flash
This may not answer your question compleatly but, the first spring was a install hight of 1.62"...... and this one seat install hight is taller at 1.700" which would reqire a diferant hight retainer or longer valve stem.................jeepinwi wrote:How can a spring with less pressure be rated for more lift?dwg86 wrote:Lunati has some valve springs part # 73084 O.D. 1.450 / I.D. 1.080 270lbs/in. That would be 101.5lbs @ installed hieght @ 1.700 and 236lbs at .500 lift. Max lift .560 . These may be easier on cam lobes. Any comments/suggestions????
Flash.
Because of coil bind. The spring might not have as many coils allowing it to have more lift before the coil binds. Go to cranecams.com and ckeck out "how to choose a valve spring" in their master catalouge.
