New Renix stroker need some help
Sjallen
- Stroker Displacement: 4.6l
- Vehicle Year: 1989
I have an 89 Cherokee that i just built a new 4.6 for, well I get it in and fired up and seems to idle good but when I give it 1/4 to 1/2 throttle it spits and sputters. I took it for a quick test spin and as long as I am just idling down the road or more than half throttle its ok but just alittle gas and it just won;t go. Does anyone have any idea what maybe the problem could be? Thanks for any help.
- Flash
Re: New Renix stroker need some help
did you index the distributor before you drop it in?
Have you cut the dist. foot or ears, so you can adj you dist.
Plugged cat?
Just the first thing that popped in to my mind.
Plugged cat?
yuppiexj
If you have indexed the distributor properly... it sounds like the CAMSHAFT position sensor is bad or unplugged.
the first item on the page.
http://www.lunghd.com/Tech_Articles/Eng ... Stator.htm
My Renix will run without the sensor plugged in but sputters anything over 1/4 throttle. (or if a good slash of water hits the connector)
easy to check.
easy to check.
Sjallen
Thanks guys for the response and it was the indexing issue..but now it has a very bad hesitation when u hit the gas off idle. Any suggestions for that?
You might need to adjust the TPS.
Sjallen
Everything is fixed and running fine...thx for all the help. Here are a few pics if anyone has questions just ask.
Sjallen
Oh yea here are some of the parts i used in my build:
258 crank and rods fully polished
802cp .030 assembly balanced
later model block and head
Head fully ported with combustion chambers
LS1 hollow stem valves 2'in/1.55ex.
titanium retainers with manly nextec springs
screw in studs and guide plates
Crower roller rockers
custom .080 wall pushrods
skimped on the header..ebay crap
all ARP fasteners
comp cams cam nitrided with camsavers
cut open, welded and raised port renix intake etc..
I'm a race engine builder by trade so i put every little trick i could into this motor but i still need 24ib injectors and a bored out tb.
all ARP fasteners
Sjallen
One more
Looks nice!
