stroker italy
heavy duty
Vehicle Model: tj
stroker italy
Post by heavy duty »
Hello everyone!
I apologize for my English!
'm going to do a stroker
what do you recommend? hesco, 505, ETCC?
Sincerely
Carlo Casanova
Re: stroker italy
How much can you afford to spend Carlo?
heavy duty
Vehicle Model: tj
Re: stroker italy
hello cheromaniac
The important thing is going strong but not break it now!
I should also mount a supercharger
Plechtan
Re: stroker italy
Post by Plechtan »
Well, if you are going to put a supercharger on it, buy the engine and Supercharger from Hesco and they will dyno it for you and set up the computer or Unichip so it runs correctly. That will probably cost you around $10,000.00 US or 6,685 Euros
Peter Lechtanski
Re: stroker italy
Hesco would definitely be the best way to go if you want a powerful engine that'll outlast your Jeep but I suspect it'll cost a lot more than $10k. More like $13k ($8k for engine, $4k for supercharger, $1k for Unichip and tune) or 9000 Euro, not to mention the cost of shipping everything to Italia.
heavy duty
Vehicle Model: tj
Re: stroker italy
I thought about it! but since I am a fan motors do it alone! then I have a friend who is a magician with the computer, unichip!
some of you have tried the 505 kit?
in your opinion what would be the compression ratio right?
heavy duty
Vehicle Model: tj
Re: stroker italy
I made two calculations with 3000 euros should do the engine
I have a motor that makes dust! the compressor as I have, for unichip EC regulations and a friend of mine who is a magician!
Re: stroker italy
heavy duty wrote:I thought about it! but since I am a fan motors do it alone! then I have a friend who is a magician with the computer, unichip!
There was someone on here that used the 505 kit. I can't remember who it was. He also had a video on www.youtube.com The video showed him pulling the left front tire while accelerating. I was impressed.
Re: stroker italy
heavy duty wrote:I made two calculations with 3000 euros should do the engine
There is going to be a bit of a language barrier here, but I'm sure we all can work through it. There are some really smart guys on this board that can help with forced induction. I'm not sure I qualify as one of them :doh: . I don't understand your statement "I have a motor that makes dust"? You already have a compressor? supercharger or turbocharger?
Hesco also has a forum you can ask questions. The owners and employees of Hesco always help out with questions.
heavy duty
Vehicle Model: tj
Re: stroker italy
sorry for the language!
I have an engine available for the stroker
I have a supercharger
mendelmax
Re: stroker italy
Post by mendelmax »
So you probably meant boost, not dust :)
But I see you are going to make a hardcore machine, that's really cool! What kind of supercharger do you have? Avenger? Rotrex?
heavy duty
Vehicle Model: tj
Re: stroker italy
say that we try to make a very powerful machine!
Rotrex supercharger! at 1 bar! (14.5 PSI)
But I can not find anyone to help me!
with a detailed list of parts that I have to take!
Plechtan
Re: stroker italy
Post by Plechtan »
People here will help, but it is your project. If you want it done for you, hire a company like Hesco. If you want to do it your self, then you have to do some reasearch. Start with Turbo Tom's thread http://www.jeepstrokers.com/forum/viewt ... ?f=7&t=354 450HP turbo stroker.
Look at some of the Supercharger kits available. You will probably have to engineer brackets and a belt setup. The comercial kits only add maybe 80HP.
If you are looking for a start, go to the FAQ section and look at the Recipies. http://www.jeep4.0performance.4mg.com/stroker.html
Everybody here is hapy to answer specific questions, but will generally shy away from questions like "Can yougive me a complete list of parts to build my stroker?"
Peter Lechtanski
mendelmax
Re: stroker italy
Post by mendelmax »
Plechtan, he already has a supercharger setup, so that's not a problem.
Heavy Duty, since you have rotrex, you have more high-rev boost than a low-end one, which may be quite usefull in a stroker (crank setup gives you low-end, supercharger aids with high-end), but AFAIK nobody yet made this kind of setup. We had an Avenger supercharged one, but this is a screw type supercharger.
The main question is whether rotrex will be able to supply the stroker with enough air. Keep in mind, that you will need at least this 15% more air, that's not so easy. But I believe it will do somehow.
Now about the exact setup, it's up to you, you have to define what you want to achieve first.
heavy duty
Vehicle Model: tj
Re: stroker italy
thanks Plechtan new
link, the compressor is exactly as I have,
how do you put photos on the site?
is what we thought (crank setup gives you the low-end, supercharger AIDS with high-end)
The Rotrex supercharger is the largest size
A friend of mine has put 2 on a ram viper and go from god!
hopefully it will be enough air for the stroker!
but in this configuration you okay?
3895 Jeep 4.2L "stroke crank
5875 Jeep 4.2L "rods
Silvola EMU-2229 +0030 "bore pistons
Increase piston dish volume to 30cc
8.75:1 CR
Ported HO 1.91 "/ 1.50" cylinder head
Mill block deck 0.035 "
Mopar / Victor 0.043 "head gasket
0.058 "quench height
Ford 24lb/hr injectors with stock 39psi FPR for '87-'95 engines, stock injectors with stock 49psi FPR for '96 and later engines
240hp @ 4700rpm, 315lbft @ 3000rpm
But bringing the bore pistons + 0040 to do a 4.7 , 28/30 lb injectors and pressure regulator pump dedicated
