Diamond Pistons
bbarrett
- Stroker Displacement: 331
- Vehicle Year: 1987
- Vehicle Model: wrangler
Diamond Pistons
I just wanted to let everyone know i ordered my pistons. The reason for the post is to give Diamond pistons a 2 thumbs up. I would recommend Diamond to anyone wanting custom pistons, The technicians are super nice people, And really know what they are doing. So to anyone wanting custom pistons, Call Diamond first. ( and the price aint bad either).
TEST
- Plechtan
- Vehicle Model: Comanche
- Stroker Displacement: 4.9
Re: Diamond Pistons
I used Diaminds in my build. Good stuff !!bbarrett wrote:I just wanted to let everyone know i ordered my pistons. The reason for the post is to give Diamond pistons a 2 thumbs up. I would recommend Diamond to anyone wanting custom pistons, The technicians are super nice people, And really know what they are doing. So to anyone wanting custom pistons, Call Diamond first. ( and the price aint bad either).
bbarrett
Re: Diamond Pistons
655.00 pistons,pins, locks, rings, Pin fitted, shipping.Plechtan wrote:How Much?
TEST
- Plechtan
Re: Diamond Pistons
Hesco sells their (diamond) pistons for $655.00 without pins, the listing does not say if they include rings or not.
http://www.hesco.us/shop.asp?action=det ... catId=7569
Locks are not used on jeep rods as the pins are a press fit. are you using rods with floating pins? Hesco has a note on their site that the rods need to be modified the clear inside the piston. It is probably just removing the excess material on the top of the rod.
Peter Lechtanski
- RAPTORFAN85
- Vehicle Year: 2001
- Vehicle Model: TJ
Re: Diamond Pistons
Rings don't come with the Hesco pistons. All you need to do to get the forged pistons to fit the rods is knock the corners off the top balance pad on the rod. Not very much either but it still has to be done.Plechtan wrote:Hesco sells their (diamond) pistons for $655.00 without pins, the listing does not say if they include rings or not.
"Strrrrroke me, stoke me...."
Billy Squire
Billy Squire
bbarrett
Re: Diamond Pistons
Yes but what compression height? Seems most want to sell you what they have on the shelf or what they recommend. I didnt want to deck the block so i got the pistons to fit the block instead of fitting the block to the pistons. I actually tried to deal with Hesco, But they didnt seem intrested. They are actually not that far from me so it would have been good for both of us. I really havent made up my mind on wheather to float or not, I got the stock size pin, So i can go either way. Leaning toward floating the pins.Plechtan wrote:Hesco sells their (diamond) pistons for $655.00 without pins, the listing does not say if they include rings or not.
TEST
Re: Diamond Pistons
What would have to be done to a stock rod to make it floating? Just remove some material and put a bushing in it?
bbarrett
Re: Diamond Pistons
SilverXJ wrote:What would have to be done to a stock rod to make it floating? Just remove some material and put a bushing in it?
TEST
bbarrett
Re: Diamond Pistons
I'm probably just going to hone the rod to the correct size and drill a oil hole. I have saw several rods in different applications that don't run a bushing, so i think ill give it a try.bbarrett wrote:SilverXJ wrote:What would have to be done to a stock rod to make it floating? Just remove some material and put a bushing in it?
TEST
- Plechtan
Re: Diamond Pistons
So a .931 chevy pin vs a .928 jeep press fit pin?
Peter Lechtanski
bbarrett
Re: Diamond Pistons
Not quite sure what you mean, But my Jeep pins measure .931. My rods measure .929. So its a .002 interferance fit.Plechtan wrote:So a .931 chevy pin vs a .928 jeep press fit pin?
TEST
Users browsing this forum: No registered users and 7 guests
