engine break in
mudslinger
Stroker Displacement: 4.7l
engine break in
Post by mudslinger »
So I am all completed assembling my 4.6 stroker and Dropped it in, broke in the cam and changed the oil. I couldnt quite find a post regarding engine break in. I was just curious if you guys could point me in the right direction for a proper engine break in
Jeep4xb4u
Vehicle Make: XJ 2dr
Vehicle Model: Sport
Re: engine break in
Post by Jeep4xb4u »
Just asked the same question a few weeks ago.
http://www.jeepstrokers.com/forum/viewt ... f=8&t=1180
With under 500-600 miles on the new engine, i'm still treating mine like i'm breaking it in and have only jumped on it less than a dozen times. :D When it comes to how i broke mine in, i took a little bit of everyones input (including outside sources) and blended them together so to speak. I also had a hell of an issue indexing my distributer which threw off my break in plans anyway. So far so good for me though, no blow by, pulls strong, and runs pretty good considering mines a Renix system.
Read what people had to say in my post about it and maybe that will give you an idea. From my recent experience, i can say that there are only a couple trusted ways of breaking an engine amd cam in, which way you choose is really based on your engine and experience.
88' XJ 2dr
4.0l / AW4 / NP231 / D35c
mudslinger
Re: engine break in
Thanks for the reply! That gives me a few usefull tips for breaking new motor in.I couldnt find that post earlier. I am also using renix motor and had similar issue with my initial startup.Began to backfire around 2k rpm. I then discovered my distributor was off one tooth. After that was fixed. It ran great! btw good job on your build. Motor looks great!
