Resizing rods for strokers
tirod
Learning to use the board
Post by tirod »
Aside from other issues in building a stroker, piston travel and it's TDC position in the bore seems problematic. Apparently the 258 crank/rod combo leaves a 4.0 piston sitting down in the bore about .040, which messes up quench. I'm leaving the small chamber/high C.R. thing out of this for now.
You can deck, or have custom pistons made, or just live with it. But, why not have the rods resized to accomodate the .040, as in make the centers further apart? Is .020 each end too much for the existing factory design? I think it would be a lot cheaper than custom pistons if it could be done. Maybe the pin end could take more offset than the crank, but even if it's just a improvement of .020 as a normal machining cost, what could it hurt?
Darn Engine Masters makes me drink coffee and think a lot.
Re: Resizing rods for strokers
I don't see how that os possible. On the small end you would have to bore the small end bigger and the install a bushing, and then have it bore off center, but the wrist pins are a press fit in the rods, so that would't work. You would need clips in the pistons to retain the rod, which would mean custom pistons. On the big end, I wouldn't want to remove that much from the cap. Its the only thing keeping the rod connected to the crank under sever loads. I think the new KB piston is going to be the best way to go.
oletshot
Post by oletshot »
On the crank end of the rod, you would have to increase the distance between centers, which throw split between the cap and rod off center. I don't think the bearings would fit properly.
'98 XJ 2-door, '94 YJ.
FrankZ
Stroker Displacement: 4.6l
Post by FrankZ »
It's much easier to just buy a piston with the proper pin height.
Post by Flash »
I like you thinking, But, it would require a floating piston pin(Custom piston)
As Frank said.......,It's much easier to just buy a piston with the proper pin height.
From tying to read between the line on one of Hesco discutions.........this is what he does with his rods...................only he buy then as a raw casting and punches the holes here he likes them ;)
astjp2
Vehicle Year: 1994
Post by astjp2 »
offset grind the crank to get the .040, I did it .020 and shaved the block .020 for a .000 deck and with the .048 compressed gasket, it was perfect. Tim
