fuel pressure and or map sensor
Cherokee Chief
Vehicle Year: 1989
Post by Cherokee Chief »
I'm in the process of doing a 4.6L stroker and I will be using the renix controller and the renix fuel rail ,24# ford motorsport injectors. What my question is do i need to use a adjustable fuel regulator and/or a adjustable map sensor?
1989 Cherokee "Notchback" 4" lift, dana30 w/4:10, dana35 w/4:10 fossy locked, Custom front & rear bumpers with removable winch.
Re: fuel pressure and or map sensor
You might need one or the other or both. You need to see where your AFR is.
Users browsing this forum: Google [Bot] and 6 guests
