My parts list
AIbandit
Vehicle Year: 1987
My parts list
Post by AIbandit »
Here's my parts list.
The Excel document has hyperlinks to most of the parts on their websites.
What do you guys think about the cam kit?
Anything I'm missing besides the cam/ rod bearings.
Should I waste money on the rocker arms?
I want to get on buying parts just want to make sure this is what I need.
Code: Select all
[noparse]
stoker parts
	                                    Price	                    Web         	Partnumber
cam/rod bearings	?	?
cam/lifters/timingchain	   139.39	  Summit
Connecting rods	                     140	Ebay
crankshaft                             170	Site	AM258-723CK AMC 258 #723
freezeplugs	                     12.9	Summit
MAP 	                                     25	Site
gaskets                                   	?	?
edlebrock headers	                   free
headporting kit                  	40	Summit
high pressure oil pump	        92.95	Summit
Injectors	                               129	Ebay
motormounts	                         240	browndog
oil filter adapter rings	        7	kragens
pistons	                            180	Summit
pushrods	                          14.7	rock auto
rockerarms	                    339	Summit
Knock sensor	                  59.79	rock auto	under emissions
Tbody	                             90	Site
tstat	                                  4.95	Summit
                  Total	1684.68
Total of items needed to start	642.29
[/noparse]
Edit: dang it won't hold my formatting
Plechtan
Re: My parts list
Post by Plechtan »
You don't say what year or vehicle engine you are starting with, so more details are required. If the cam you selcted has much more lift than stock, you will need different valve sprngs.
See the spreadsheet undet the topic "how much did you send onyour stoker" ( sticky at the top of this forum), it may give you some idea avbout some of the ther parts you will need.
Peter Lechtanski
AIbandit
Vehicle Year: 1987
Re: My parts list
Post by AIbandit »
Renix 4.0 going for the 4.6
running the 99+ intake and the 7120 head
Re: My parts list
The $90 t-body is for the renix? Also, you don't need a hv oil pump--a standard will do the job just fine.
AIbandit
Vehicle Year: 1987
Re: My parts list
Post by AIbandit »
The Tb is for the 91+ from Leigh performance (running a 99+intake)
AIbandit
Vehicle Year: 1987
Re: My parts list
Post by AIbandit »
Plechtan wrote:You don't say what year or vehicle engine you are starting with, so more details are required. If the cam you selcted has much more lift than stock, you will need different valve sprngs.
Thanks plechtan
That cam kit comes with springs. Same one you're running 68-231-4
Looks like our costs are about the same minus the F&b and gaskets/bearings and your headers (I got mine for free woot :D http://www.summitracing.com/parts/EDL-65923/)
That list will definitely help picking up the little things thanks.
yuppiexj
Re: My parts list
Post by yuppiexj »
AIbandit wrote:Renix 4.0 going for the 4.6
If you have visual emissions inspections (meaning the hood is opened) and this is a road vehicle and the inspector pays a lot of attention, you will fail said inspection due to lack of EGR (even though the new engine will pollute less than an old worn out engine when tuned).
I have the same issue (90XJ with a 7120 head and 99+ intake in the works)
AIbandit
Vehicle Year: 1987
Re: My parts list
Post by AIbandit »
Thank you for you're concern. I do know about this and my vehicle is no longer street.
47" LTB's, Rockwells, Atlas 2 4.3:1
Re: My parts list
Are you going to adapt the renix tps to work on the obd1 tb? Might want to take a look at http://www.hesco.us/shop.asp?action=det ... 563&catId= to get an idea.
AIbandit
Vehicle Year: 1987
Re: My parts list
Post by AIbandit »
Yeah I'm aware of it. I don't know whether or not I'm going to cough up the cash or try it myself. I think there's a naxja thread about it somewhere.
Users browsing this forum: Google [Bot], Semrush [Bot] and 1 guest
