Rivets on the mp head gasket?? Need help quick
LetchcoreCJ7
- Learning to use the board
- Vehicle Year: 1983
- Vehicle Model: CJ7
What's up with the rivits on the mp head gasket? Wont they stop the head from mating properly with the block? Have others seen this? They look like brass and hold together the 3 layers.
1983' Jeep CJ7 w/ 4.6L stroker, NSG370 6 speed trans, D300.
91' 4.0L engine, 0.030 over, 4.0L rods, 4.2L crank, KB944 pistons, Stock head w/ Mopar springs, Mopar cam, Mopar roller timing chain, Mopar oil pump, Hesco CPS relo kit, SS header
Re: Rivets on the mp head gasket?? Need help quick
Don't worry about it. They fall in areas where there is no block or head on at least one side of the gasket. When I first did a head gasket on the 4.0L using a MLS I had the same question.
LetchcoreCJ7
Well I removed the rivets where they where going to hit a surface and left the ones that where not. Everything aligned up so all should be good!
Alex22
Those rivits are important to keep the gasket lined up correctly while you are installing the gasket. SB Fords have that same issue, we just drill a small hole in the block for the rivet to fit into, its not in a critical area.
