258 conn rod bearing width?
bikedude189
Post by bikedude189 »
just started assembling my stroker and the connecting rod bearings for the 258 rods are have about 1/16 - 1/8" of clearance on each side. ie; they are narrower than the rods by that much... i don't know if this is normal as i don't have the original 258 rod bearigns. it seems like the bearing should over the entirety of the rod surface and also the bearign surface on the crank...
a fast answer would be awesome as i'm currently assembling...
Re: 258 conn rod bearing width?
The bearing clearance should be .001-.003", with .0015"-.002" being optimal, so yeah something's up. The side clearance should be .010-.019"
Federal Mogul shows their AMC/Jeep rod bearings are .837" wide, don't know why they would vary form the OEM bearings.
The shell is narrower than the journal to clear the fillet radius.
Plechtan
Post by Plechtan »
A standard Jeep rod is 1.060, with the bearing width being .837, that does give you about 1/8' clearance per side.
Peter Lechtanski
