05 TJ 4.0 into an 01 XJ?
hot_rod_hooligans
- I think I'll order a "tab"
Is there any difference in the long blocks between the TJ/XJ? I have a 4.0 from a 05 TJ with two of the bolt bosses broken off and am looking at the M.O.R.E. Bombproof Engine Brackets as a way to bypass the damaged area, but the guy at M.O.R.E., was telling me that the mounting provisions from the XJ to late TJs were different.
yuppiexj
Re: 05 TJ 4.0 into an 01 XJ?
