Crank Pulley??
hvacman
Crank Pulley??
Post by hvacman »
I was goign to put on the crank pulley and it is fitting real tight.
So I got to thinking. Are the pulleys from the 4.o and the 4.2 different? Should I use the 4.2 pulley?
If I have to use the 4.2 pulley, do they make a pulley that uses a serpentine belt setup? My old 4.2 pulley is for a v-belt.
Also, I noticed that the shop that did the rebuild left a "shim" or something inside the timing cover. It appears it may be a dust shield for the seal. I say this becasue there is a slot cutout for the keyway on the the front of the crank. Guess I need to pull the timing cover and remove it. It just rattles around in the timing chain area.
Re: Crank Pulley??
You need to use the 4.0 harmonic balancer on a stroker. You'll need to put a 1cm thick spacer in front of it if you have the longer nosed '72-'86 4.2 crank.
hvacman
Re: Crank Pulley??
Post by hvacman »
Thanks.
I used the crank out of an 89 258. Hope it is the right size. If not, I will get the spacer from Hesco.
Re: Crank Pulley??
hvacman wrote:Also, I noticed that the shop that did the rebuild left a "shim" or something inside the timing cover. It appears it may be a dust shield for the seal. I say this becasue there is a slot cutout for the keyway on the the front of the crank. Guess I need to pull the timing cover and remove it. It just rattles around in the timing chain area.
The "oil slinger" is supposed to be in there.
hvacman
Re: Crank Pulley??
Post by hvacman »
This slinger is extremely loose around the crank. Are they usually pretty loose?
It also has a keyway slot cut in it. If it went on below the key way, I would have thought it would not have a keyhole slot.
It is all good though. It appears I don't have to remove the front cover.
Re: Crank Pulley??
Its will be lose until the crank is tightened up against it. It goes all the way against the crank.
Re: Crank Pulley??
hvacman wrote:Thanks.
In that case you won't need the spacer. The '87-'90 258 cranks have the same 54mm long nose as the 4.0 cranks.
hvacman
Re: Crank Pulley??
Post by hvacman »
Too cool.
Thanks guys.
