Thanks
what style of 4.2 crank?
4.0l sahara
I know that there are two styles of cranks used in the 4.2 . Am I right that the 12cw crank is better? why?
Thanks
Thanks
Chris
- Learning to use the board
Re: what style of 4.2 crank?
The way I understand it, the 12w is better for low torque low speed applications such as rock crawling. The reason is it has more weight, so once it gets to spinning, it is harder to slow down...aka - momentum. The lighter ones will rev quicker, and are more for high speed applications. I don't think there is really much of a noticeable difference though. I could be wrong on this, but I read it somewhere, so
I saw that coming, yet I did nothing to stop it....why do I fear success...
..,====,o00o
//__l_l_,\____\,__
l_---\_l__l---[]lllllll[]
_(o)_)__(o)_)--o-)_)___
..,====,o00o
//__l_l_,\____\,__
This seems to be the general consensous...Chris wrote:The way I understand it, the 12w is better for low torque low speed applications such as rock crawling. The reason is it has more weight, so once it gets to spinning, it is harder to slow down...aka - momentum. The lighter ones will rev quicker, and are more for high speed applications. I don't think there is really much of a noticeable difference though. I could be wrong on this, but I read it somewhere, so
viewtopic.php?f=27&t=51
Although when i build mine im going to try the 4cw.
seanyb505
- Stroker Displacement: 280ci
As far as strength goes I have yet to read that either has an advantage/disadvantage. I have read that the 4wt is more vibratious. No real world experience, give more 3 months Ill let you know.
97 XJ 4.6
90 MJ 4.0 - sold
97 XJ 4.6
90 MJ 4.0 - sold
I wanted less weight and faster spool-up so that's why I traded a 12cw for a 4cw. I'll find out in a month. . .
I'm even scheming on a light-weight flywheel, so you know who I have to give a call to. . .
seanyb505
Ghostbusters?
97 XJ 4.6
90 MJ 4.0 - sold
97 XJ 4.6
90 MJ 4.0 - sold
ha-ha-hesco
- Vehicle Make: Jeep XJ
Each has its own advantages but in the real world, either will do very well:4.0l sahara wrote:I know that there are two styles of cranks used in the 4.2 . Am I right that the 12cw crank is better? why?
Thanks
12CW: Less vibration (more counterweights), extra 20lb like having a heavier flywheel (engine doesn't stall when rockcrawling at very low revs), better choice for endurance racing.
4CW: 20lb less weight over the front wheels, engine revs up faster, better choice for drag racing.
seanyb505
Youll have to switch to an auto trans type starter. Taken from Hesco - "The flywheel does not come with a ring gear and is designed to be used with a automatic flex plate that will match your existing electronics..." "May also be used with manual transmission using an automatic transmission starter ring to complete installation."gradon wrote:ha-ha-hesco
97 XJ 4.6
90 MJ 4.0 - sold
97 XJ 4.6
90 MJ 4.0 - sold
Yeah I went to Hesco's site months ago and saw the auto-flexplate, but thought there was a different p/n for the manual-flywheel since I had read comments about it from somewhere(I'm gonna hold off before I drop $350).
stroked'73
- Vehicle Year: 1973
- Vehicle Model: Wagoneer
Don't Hays, Ram, Centerforce, etc. all make aluminum flywheels also?gradon wrote:ha-ha-hesco
Moneywise they're probably all in the same ballpark, though.
Centerforce makes one for an older model jeep IIRC--I'll search around and let y'all know what I found.
Shark
ill take a 4cw if anyones got an extra.
'95 XJ 4door 4.0 aw4 2" 31's
No luck on the light-weight aluminum flywheel. I did shoot an email to Fidanza. They make light-weight aluminum flywheels and have a HD 39# steel one for our 4.0s so they might be able to make a light-weight one. Some of their flywheels weigh 13-18#s, which would be nice. I also googled "custom flywheel" and shot an email to a JB Racing(IIRC) in Florida. Since I have to wait on the pistons and block work, I'm tempted to give Yella Terra a call(I'm not sure I want to reuse the stamped rockers-esp with the additional lift of the 30ab).
