Valve spring shims
mike0914nascar
- Vehicle Year: 1982
- Vehicle Model: Cj-7
Valve spring shims
I've lapped in my valves and can't find the info on what the inner and outer diameter should be for the valve spring shims used on a 7120 head.Also what is the stock valve stem height,and valve spring hieght on this head.Thanks
Re: Valve spring shims
Why did you lap the valves in? That usually causes more problems than good.
Stock install height is 1.64"
