fuel rail / tranny line o-ring kits
- gonridnu
- Vehicle Year: 1989
- Vehicle Model: XJ 2 door
Does anyone know where to get the o-ring "modules" that fit the fuel lines and tranny lines other than at the dealership where they are like $10 a pop? I'd like to replace them all while in there and that equates to about 9 units or so. Does Napa have them? If so can someone supply a part number?
yuppiexj
Re: fuel rail / tranny line o-ring kits
if you have bulk o-rings simply get the clips themselves from your local parts store.
Dorman (AKA HELP! brand) 800-005 and 800-006 (5/16" and 3/8" respectively)
Should be around $4 each.
if you want to dig for the full reload kit part number, here's a starting point:
http://www.dormanproducts.com/c-386-fue ... iners.aspx
Bodo
Try BK 730-4978. It's a transmission line connector.
Users browsing this forum: Ahrefs [Bot] and 4 guests
