supercharger motor build
shintastrife
Post by shintastrife »
im needing some in site, im look at build a supercharged 4L by im need help finding parts. im trying to just change the crank out to a less stroke to drop the compression, and a mild cam for so it can breath better. im planning on porting my head as well but im not shear how much, and was thinking for build a custom header as well to open it to eather a 2.75 or 3'' with a magna flow cat and the sheath sires muffler
SIXPAK
Stroker Displacement: 280
Re: supercharger motor build
Post by SIXPAK »
Reducing stroke is not the best way to achieve a lower compression. By trying to do this piston to haed clearance will be increased and therefore increasing the probability of detonation. Detonation on Turbo/Supercharged motors is what you will combat the most due to the higher temperature of the intake charge. I'm not the best source of info on forced induction stuff but with that said if you plan on running lower boost levels stock components could work if a few things are addressed. .PAGING----------TURBO TOM--------push away from the beer cooler, help this feller out!
shintastrife
im only looking to push 5 pis, im not wanting to go turbo do to heat form exust heated meal + fast cool down = cracking.
im trying to get around boosting gas in take its dtd driver so the more mpg the better. i gotten qouts on what getting a .125 shim for the head and its going to run around 300 buck b/c of he being cnc milled.
i want more power but im trying to get keep fairy good mpg as well.
Jak Flash
Vehicle Year: 1994
Vehicle Model: YJ
Post by Jak Flash »
Dude... you are thinking way in the wrong direction....
to run a supercharger you need to have the engine tuned in... running a nice tight quench and a compression ratio of about 9:1. by adding a spacer you are openning yourself to a world of hurt. the Predetonation is going to Kill you.
you can put a root style blower on your 4.0L stock. make some changes to the injectors and a better fuel managment system and your golden. Do some searching before you commit.
and BTW... you will never get better gas milage on a Jeep by putting a blower on it. its a myth... FYI
good luck with your build. post up pictures etc when you get started.
here's a thread on pirate
http://www.pirate4x4.com/forum/showthread.php?t=854074
shintastrife
that's why im here and just out building it. i know ppl have dont it before so something close to it. im looking for in put an help.
by posting that link your helping me out.
