Ok I am running this combo! 1994 block 1988 head
4.6L "poor man's" stroker
Jeep 4.2L 3.895" stroke crank
Jeep 4.2L 5.875" rods
Sealed Power 677CP +0.020" bore pistons (.030)
9.25:1 CR
Stock 4.0 HO camshaft
Ported HO 1.91"/1.50" cylinder (head 88 head)
0.088" quench height (.093)
Ford 24lb/hr injectors with stock 39psi FPR for '87-'95 engines, stock injectors with stock 49psi FPR for '96 and later engines
248hp @ 4900rpm, 303lbft @ 3500rpm
Broke in just fine with the recommended 20 minute cam brake in! Changed oil and took for test drive! Jeep started to sound like a diesel.
Took pan off checked main rod bearings and everything was just fine. Pulled head and found cylinder/piston scoring.
When assembled all tolerances where in check!
Rod Knock
stege123
- Vehicle Model: rubicon
Re: Rod Knock
Bad luck.
Please send pictures so it is easier for us to determine cause of trouble.
I'm reading your specs, and you used 020 pistons and are writing 030. I consider this a slip of the pen.
Many people do the break in of the cam correct, but forget to break in the piston rings. Did you break in your rings??? Gap of your rings OK.
Was the engine overheated?? Was all the removed antifreeze replaced with enough antifreeze??
Please be more specific and send some pictures
- Vehicle Make: Jeep XJ
Re: Rod Knock
I see you used +0.030" pistons which is fine, but did you use +0.030" rings? Something's seriously wrong here and some pics might help.tbalcome wrote:Pulled head and found cylinder/piston scoring.
