Oil bypass valve?
Bodo
Oil bypass valve?
Post by Bodo »
Do our Jeep I6 motors have a oil filter bypass valve in the filter adapter? I don't remember seeing one when I tore the old one apart.
Thanks!
lafrad
Re: Oil bypass valve?
Post by lafrad »
The filters you use should have a bypass built in. Hopefully it never has to be used...
Te filter has a bypass valve for when it reaches capacity. The oil pump has a bypass for when it reached the pressure of the valve.
Bodo
Post by Bodo »
Great, thanks! I know that some engines have a little valve that should be replaced when you rebuild.
It's been a year or so since I tore the old one down...
thanks again.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 3 guests
