What thermostat should i use with my 4.6L Stroker
jeeptj01
- Vehicle Year: 2001
- Vehicle Model: WranglerTJ
I am running a 4.6L Stroker in my 2001 jeep wrangler and i was wondering should i be running the stock 195 thermostat? I guess the reason why im asking is because when ever i use my a/c my jeep gets too hot to the point where i have to let it cool in order to start it. It only happens when its really hot out or i use my a/c. Should i try a 180 thermostat?
- IH 392
Re: What thermostat should i use with my 4.6L Stroker
Run the 195, if you run a colder one the computer will never change to closed loop, something else is wrong, fan clutch?, radiator plugged?, crappy water pump?, is the shroud still on it?
I am running a 180 with my stroker. It's been very hot down here in the southeast (101 yesterday), and I don't have any problems with overheating while running my a/c. The hottest its ever got was about 205 in stop and go slow traffic (in this hot 95+ temp). Also no problems in the winter time warming up to get the computer in closed loop.
Still, look for other problems. Your jeep shouldn't overheat even with a 195 thermostat.
Flush the whole cooling system, install new hoses, and refill the system with fresh coolant. There's a good chance that your radiator is clogged up with crud.jeeptj01 wrote:I am running a 4.6L Stroker in my 2001 jeep wrangler and i was wondering should i be running the stock 195 thermostat? I guess the reason why im asking is because when ever i use my a/c my jeep gets too hot to the point where i have to let it cool in order to start it. It only happens when its really hot out or i use my a/c. Should i try a 180 thermostat?
- amcinstaller
- Vehicle Year: 1980
- Vehicle Make: AMC
- Vehicle Model: Spirit
look in between the rad and condenser as well, lots of buildup likes to stay in there. when i worked in the a/c shop, we would see cars with solid bugs and dirt in between the two alot.
- StroktWJ
- Vehicle Model: Grand Cher
I run a 195°in my 4.6L stroker with the AC on and am ok also.
#727 Crank
Clevite 3415 Pistons
91-95 Camshaft
7120 Head
00 Intake
Magnaflow Muffler
Offroad Pipe
#727 Crank
91-95 Camshaft
7120 Head
00 Intake
Magnaflow Muffler
Offroad Pipe
apwatson50
I ran the 180, in mine for a while, until winter came in the mountains and the wife was complaining about no heat:( So the 195 went back in, it never overheats in the summer a/c on. But I also put the big 3-core brass radiator in it when I did the engine.
1997 cherokee auto.
stroked 4.6L, 10.25scr, and some other stuff.
Users browsing this forum: Ahrefs [Bot] and 9 guests
