oil galley plugs
- Vehicle Model: cherokee
oil galley plugs
Just got my block back from the shop and was looking for some info on the oil galley plugs. I can see one on each end of the block just wondering if there are any more than those two? and if so where are they located , btw it is a 97 block.
Re: oil galley plugs
Those are the only two.
- Stroker Displacement: 4.9L
- Vehicle Year: 2001
- Vehicle Model: GC
Are these the oil gallery plugs ur talking about?
No. 5
Part # 06034166
Quantity: 3
ER0
Nomenclature: PLUG, Cylinder Block Oil Hole
I know my stroker didn't have the forward one installed. Also, the forward one opens into the area below the #1 piston. There is no physical gallery there. Makes me question the purpose.
No. 5
Part # 06034166
Quantity: 3
ER0
Yes, those are the plugs. I don't know why they show one above the oil filter other than for a TJ or WJ, which has the oil pressure sender at the rear of the gallery. The front one opens to the timing cover area and is necessary.
