2.5 ore 3"exhaust
paulv
Stroker Displacement: 4.5
Vehicle Year: 1986
2.5 ore 3"exhaust
Post by paulv »
i''m building a 4.6 stroker for my yj wrangler . it's going to be my daily driver. 99% road use
i just bought an borla header, but it's for a wrangler TJ so i'm going to cut of the collector and turn it around so it wil fit my YJ .
should i weld 3" exhaust pipe's to it, ore should i leave it like it is (2.5")
i.m going to use a borla muffler and no cat. converter.
add. info. 3.55 gears, 31 bf goodridge, carb. and hei, offenhauser, lpg convertion 9.6 -1 compression . 210-218 comp cams camshaft
thanks for your help.
Paul
the netherlands
paulv
Vehicle Year: 1986
Re: 2.5 ore 3"exhaust
Post by paulv »
i just received my borla header.. what a disapointment!!
ok great design. but the primairies have the same diameter piping as original, the collector is 2.25" :doh: and the end pipe is 2.5"
why in gods name do they make a 2.25 "collector and then go to a 2.5" end pipe.??
i'm going to cut of the collector and weld a 3" exhaust on to it..
what size of exhaust are you guys using???
thanks,
Paul
the netherlands
I think it all depends on what your doing with the build. Even for most stroker builds 2.5" is plenty.
I'm running a 2.5" exhaust. Most people are too considering most after market performance type systems are 2.5".
paulv
Vehicle Year: 1986
Post by paulv »
the plan is to make it a "fast" daily driver.
if the borla header had 2.5" collector i would keep it like it is . but it's only 2.25" :huh:
so i want to cut it off anyway. :deadhorse:
should i step up to 3" ore keep it at 2.5 " i havent bought anything yet. think i'll go for 3 "
better to big than to small..
paul
the netherlands
YJason
Post by YJason »
I run the Borla 17202 header, like this:
I have it running into 2-2.25" pipes down in front of the oil sump where it goes into 1 3" pipe and then wraps around and runs parallel to the frame back to a 50 series flowmaster. It then steps down to a 2.5" pipe out the back. There isn't much room between the gas tank and the leaf spring for a 3" pipe, plus I figured it needed some back pressure for the FI and fuel mileage. It sounds really cool, I have people on the trails aask me all the time what kind of engine is in it.
There is a thread on here somewhere that discusses the optimal exhaust size, iirc it was 2.75"
astjp2
Vehicle Year: 1994
Post by astjp2 »
2.5 inch is all we need for a stroker, any larger is a waste of money. The exhaust cools and slows down as it gets to the tail, so a bigger pipe diameter is not necessary.
