low ambient temps + install ?
sudo chop
Post by sudo chop »
Man, it sure is getting cold around here. This is my first time putting an engine together, so I have no idea how much it matters. I get nervous enough just starting my truck that I know nothing is wrong with in the cold. I am extra nervous about getting the stroker in soon and its first start being 25* outside.
Is there any real concern here? Is there anything I should do differently or look out for?
unlimitedrubicon
Vehicle Year: 2005
Re: low ambient temps + install ?
Post by unlimitedrubicon »
I am there with you. Should be dropping it in tomorrow pending on the weather...
I would try to heat the oil up or keep it in a warm place until your ready to put it in, prime, and fire. Get it fired and break the cam in.
sudo chop
Post by sudo chop »
I guess I should probably use a pretty light weight oil for the break in. Like 5-20 or something?
I could put a propane heater under the pan for a while, that might work well...
Vehicle Year: 1980
Vehicle Make: AMC
Vehicle Model: Spirit
Post by amcinstaller »
do you guys have block heaters there? if not propane heater underneath should be fine. but definately make sure the oil is warm and thin. 25 farenheit is just below freezing so it shouldnt be so bad.
lafrad
Post by lafrad »
use a standard 5W-30 with the proper cam break in lube.
Leave the oil in the house , but honestly, if the block is cold the oil will just cool down to block temperatures QUICKLY. there is a lot more thermal mass to the iron than oil.
A block heater would really be your best bet, get the WATER warm.
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Semrush [Bot] and 2 guests
