MLS head gasket
montelibre
MLS head gasket
Post by montelibre »
Hi
I need to buy a head gasket set (MLS and bore 4") + bolts for my Stroker 4.6L (The cylinder head is the year 1996).
Where are I can buy?
At Summit Racing I saw a cylinder head gasket, but the bore is 3.875".
Thanks.
Re: MLS head gasket
Cylinder head bolts: http://www.summitracing.com/parts/FEL-ES71102/
Head gasket: http://www.summitracing.com/parts/DCC-4529242/ (bore is actually 4.0" and I know 'cause I've used the same one before)
4.whoa
Vehicle Model: xj&mj
Re: MLS head gasket
Post by 4.whoa »
Make sure you tell the machine shop you plan to run a MLS gasket because they need to surface the head and deck differently to ensure a proper seal with one. :cheers:
-Russ
