Anyone ever see this?
racing89
Stroker Displacement: 306 ci
Vehicle Model: comanche
Post by racing89 »
Finally got around to pulling my daily-driver stroker apart. Belive it or not , it still run (a little noisy though)Anyone ever see this?
basscat
Vehicle Model: TJ Sport
Re: Anyone ever see this?
Post by basscat »
:o
How did that happen?
You should be able to JB weld it back together and be good.
I6FAN
Stroker Displacement: 4.2
Vehicle Year: 1987
Post by I6FAN »
Was that a new or used crank, and was it Magnafluxed before your build?
SilverXJ wrote:You should be able to JB weld it back together and be good.
I would use super glue myself.
I've replace several Wisconsin V4-65 crank shafts that were snapped in half, never seen an AMC crank broken like that?
racing89
Post by racing89 »
It was just left over pieces from our race program that I slapped together 5 years, 100000 kms, and many rpms ago. Was magnifluxed(I think). I hope my new 4.08 stroke crank doesnt end up like this!
What rpms did it get up to? Any specific sustained rpm? Which crank is it(12-weight, 4-weight long snout, or 4-weight short snout)?
racing89
Post by racing89 »
4 weight long snout. never over 6x grand. thinking balancer issues, as I have had in the past, suspicious, abnormal wear on the snout where the balancer rides.
Jeepsr4ever
Stroker Displacement: 491ci
Vehicle Year: 1974
Vehicle Model: cj5
Post by Jeepsr4ever »
Looks like a typical fillet radius break. I believe those cranks have a 3/32 radius on the rod journals this makes then prone to cracks and possible breaks. Most will try to get 1/8" radius or larger. Bummer! Hopefully your rod isnt bent and you can just swap in another crank and bearings. When you have a break like this sometimes the wrist pin does a number on the piston pin bore so if your plan is to rebuild have it all looked over.
6TIME
Vehicle Year: 1993
Vehicle Make: JEEP
Vehicle Model: CHEROKEE
Post by 6TIME »
:o Yikes! I hope my 4wt crank doesn't do that!
racing89
Post by racing89 »
just gonna be a spare. Was sonic tested and cant go much over the .040" its punched out. Ring gap 100000 kms ago was pushing .026".Have old race engine (4.0" bore 3.902 stroke) to put in my 88 comanche daily driver for now. Cant wait ! Been driving, knocking stocker for 8 months now!
Jeepsr4ever
Vehicle Year: 1974
Vehicle Model: cj5
Have you been pretty happy with the power?
racing89
Post by racing89 »
Very much so, although I didnt fully appreciate it untill I had to install a stock 4.0l
racing89 wrote:thinking balancer issues, as I have had in the past, suspicious, abnormal wear on the snout where the balancer rides.
Agree. The crank broke at the front so the most likely reason is indeed a balancer issue. I've seen cranks on other engines break in the same place when they've been supercharged, probably because of overtight blower belts.
Spliffotticle
Stroker Displacement: 4.59L
Vehicle Model: WJ
Post by Spliffotticle »
I have blown 2 4.0l engines due to piston slap. I remember when things were made out of metal : ( Yours is new to me.
bored, check. stroked, check. turbocharged, check. functional, information unavailable
