Max spring pocket/seat cut depth?
Whats the max amount anyone has cut out of the spring pocket/seat or the usual amount? I know that you need to cut for Hesco's springs but I don't have a figure on how much needs to be cut out.
Re: Max spring pocket/seat cut depth?
Are you going to run a different spring?
shawnxj
- I love this board
- Vehicle Model: cherokee
i'm going to run the lunati springs and according to the tech guys i shouldn't have to cut the pockets at all. i'll know for sure in the next couple weeks
SIXPAK
- Stroker Displacement: 280
.125" EASILY, I have cut some as much as .250"
Its for spring locators. Only .060" thick
What are the spring specs? Will they work with the stock retainers?
SIXPAK
Cut away you will be fine sir!SilverXJ wrote:Its for spring locators. Only .060" thick
Who are you asking?dwg86 wrote:What are the spring specs? Will they work with the stock retainers?
That is what I thought. Just wanted to verify before something bad happened.SIXPAK wrote:Cut away you will be fine sir!SilverXJ wrote:Its for spring locators. Only .060" thick
Who are you asking?SilverXJ wrote:dwg86 wrote:What are the spring specs? Will they work with the stock retainers?
I'm asking SilverXJ.
It would be nice to have an alternative spring to use.
They are just the Mopar performance that I have been using.
djergensen
- Vehicle Year: 1994
Did you decide to cut the spring pockets? I also have the lunati springs/cam and they are coming in a bit to much pressure 135# at 1.65 - so he suggested .125 but in not sure the depth - before hitting the water jacket. .125 will work?
