Mopar Performance valve springs p5249464
Advance auto parts sells mopar performance valve springs p5249464 for $6.99. Best price I have found so far. Go to www.advanceautoparts.com, click on shopping and enter p5249464 in the search. These valve springs have a 270# spring rate, and install the same height as stock springs. Good for up to 525 lift. The spring rate is less than comp cams and crane cams springs recommended for thier cams. Should be easier on camshaft lobes.
Re: Mopar Performance valve springs p5249464
Mine are working good so far! I should've had my brother check for those before buying from Mopartsracing--I could've saved $3.55x12=$42.60.
