oil slinger
brokenujoint
Vehicle Model: Tj
oil slinger
Post by brokenujoint »
So I hear that some engines use an oil slinger and some don't. I've got a 97 block with a 12 wt crank. Do I need a slinger or not? Also, which harmonic balancer should I purchase? A 258 model or a 97 4.0 (which is what the block is) :doh:
Re: oil slinger
A 4.0L balancer for your year vehicle is what you want.
If you get a Mopar balancer, remove the oil slinger. If you get an aftermarket keep it. I would recommend a Powerbond balancer over other aftermarket ones. Dorman is made in China and the Professional Products didn't come with a timing mark. Regardless of which one you get have your machine sop balance it. Everyone I had was out of balance to some extent.
jbxx
Vehicle Year: 1986
Vehicle Model: CJ7
Re: oil slinger
Post by jbxx »
I was told by Jeep that if you use a Mopar balancer, that there was a TSB stating not to reuse the slinger.
Confirming Silvers' previous post.
J.B.
Re: oil slinger
That is what I heard as well.
zebracar1
Vehicle Model: grand
Re: oil slinger
Post by zebracar1 »
Im a chrysler mechanic and I can confirm there is a TSB to not use the slinger.
brokenujoint
Vehicle Model: Tj
Re: oil slinger
good. I'll get the Mopar one and have it balanced. No slinger is one less thing to worry about . Thanks guys. :banana:
