dorman oil pump drive
- Vehicle Year: 2001
- Vehicle Model: wj
if you have wierd idle issues that seem to come and go,stalling ,rough idle below 1000rpm replace the cam sensor.will usually pull codes that would make you look at the crank sensor but it is the cam sensor from dorman.drove me nuts until i finally pulled the one off my old motor and tried it.not heat related either just whenever it feels like it!
