Question on valve springs!
casual
Vehicle Model: xj
Post by casual »
I'm looking at buying a used 4.0 head and it appears to have aftermarket valve springs in it..I asked the guy to measure the valve spring diameter & the distance between each loop/coil of the springs...They are installed, so he checked the distance between each coil...
Anyway spring diameter was .1545 and the spacing between each loop is .1430..anyone can you confirm if these are stock springs? Or possibly Mopar springs? Any other way to tell?
Antifreeze2
Stroker Displacement: 280 ci
Re: Question on valve springs!
Post by Antifreeze2 »
Stock info from AllData
Free Height: 1.876"
Inside Diameter: 0.827 - 0.847"
Installed Height: 1.640"
Closed pressure: 61-69
Open pressure: 184-196
Here's a table of mopar springs
casual
Vehicle Model: xj
Post by casual »
Nice! Thank you..I couldn't find info anywhere!
Any specs on stock springs?
Antifreeze2
I believe the second one on the mopar list is the stock spring, even though it doesn't help much. The OEM part number from Alldata is 53010388.
If it is a Mopar performance spring, it will have a damper on the inside--which is like a second spring, but looks more like a ribbon.
