To get a stroker or rebuild?
Erds
Vehicle Year: 1991
Post by Erds »
I have a 1991 Jeep Wrangler 4.0l with 125,000 miles. I have a constant lifter noise that won't go away, also a timing chain that needs to be replaced. Am I better off to replace the lifters, cam, timing chain on this 20 year old motor or go to a 4.6 stroker from one of the professional stroker builders? All advise is welcome.
Re: To get a stroker or rebuild?
Erds wrote:I have a 1991 Jeep Wrangler 4.0l with 125,000 miles. I have a constant lifter noise that won't go away, also a timing chain that needs to be replaced. Am I better off to replace the lifters, cam, timing chain on this 20 year old motor or go to a 4.6 stroker from one of the professional stroker builders? All advise is welcome.
I think this all depends on your budget and what your looking for out of your Jeep.
If you are ok with Stockish power and have limited funds, then just do a rebuild. If you have some money to spend and are craving power then build the stroker.
Erds
Vehicle Year: 1991
Post by Erds »
If I go with the stroker motor who would you recommend be the builder, I have read bad reviews about Golen and Titan. Looks like maybe the Mopar stroker?
Erds
Vehicle Year: 1991
Post by Erds »
Has anyone ever heard of Larry's racing engines out of Groton, Ct.?
If you don't want to use someone local I would go with Golen, ATK, or Hesco (if you have the cash).
Missourian
Post by Missourian »
If I understand correctly, ATK is building the STROKER that Jeep is selling as a MOPAR 4.6L STROKER.
Please correct my statement, if this is incorrect.
Vehicle Year: 1980
Vehicle Make: AMC
Vehicle Model: Spirit
Post by amcinstaller »
that was a tidbit flying around the internet for a while but it was never confirmed or denied reliably, at least as far as i read.
I've heard that ATK does make the strokers for Mopar, but its a bit different from theirs.
fsjeep13
Post by fsjeep13 »
Sounds like you are almost in the same boat I am in.
Have any of you guys heard of West Coast Engines?, its a subsidiary of Motor Works in Spokane, WA. They have a 4.0L and a 4.5L stroker. I have been seriously considering an engine from this company. Any reviews or anything? Its an idea. They are registered with the Better Business Bureu and from what I can find, good reviews.
http://www.westcoastengines.com/#/shop/ ... 4.0/565867
http://www.westcoastengines.com/#/shop/ ... KER/534413
Wagoneerxj
Post by Wagoneerxj »
That 4.5L stroker from West Coast Engines seems like a steal at $1899. Spokane is only a couple hours from here too..... :mrgreen:
98 XJ 2dr 4.0L, 4.5" and 33's
97 XJ 4.0L, 2" and 235/75's
87 XJ Wagoneer 4.0L, 5" and 33's
93 XJ 4.0L (Dad's) 2" and 235/75's
97 TJ 4.0L (GF's), 4" and 33's
