Newbie question about computer and injectors
bradcarrier
- Vehicle Year: 1995
- Vehicle Model: wrangler
New guy here, purschasing a 4.6 Stroker based on the RockCrawling stroker build, supposidly 235ish hp and 300ish torque. Its going in my YJ which is a 95 model, ax-15 5 speed trans. I have heard some different things but mainly that I need 24lb injectors, will the stock computer and fuel pump be Ok? since its OBD1, how will the computer act. Also what 24lb injectors do I need to get for my setup that will be plug and play.Thanks!
Re: Newbie question about computer and injectors
You can get the OBD I type 24lb blue Ford injectors with EV1 connectors from ebay and yes, the stock computer and fuel pump will do fine.
bradcarrier
Yup. They'll do fine.
