What clutch to run with Ax-15 and stroker
bradcarrier
- Vehicle Year: 1995
- Vehicle Model: wrangler
Gettin ready to install my stroker, based on Rockcrawler build, gonna reuse my Ax-15, what clutch should I run, I assume stock will not cut it. Thanks
Re: What clutch to run with Ax-15 and stroker
I don't know whether the stock one will hold or not, but I have heard Luk clutches are highly recommended.
604rail_king
- Vehicle Model: XJ
likely a Center Force DF or ACT kits would hold the tq
- IH 392
I got an OE SACHS clutch to run with my stroker, the OE one in my Jeep now has 147K miles on it and has NEVER once offered to slip!?, the AX-15's on the 4.0's use a 10.4" disk, that's V8 territory!
- Missourian
I opted to go with the Centerforce II to go behind my STROKER being installed here shortly.
bradcarrier
I've heard some other people say stock will hold up, where is the best place to get a luk clutch and which one should I get
bradcarrier
Ordered a Luk Pro Gold for 151.00 from partsgeek
Wagoneerxj
What about SPEC clutches? Like the SD651? I run a high hp SPEC clutch in my mustang and love it. No slip, easy pedal. Anyone ever used one in a Jeep before?
http://www.redlinemotive.com/part-numbe ... /sd651.asp
98 XJ 2dr 4.0L, 4.5" and 33's
97 XJ 4.0L, 2" and 235/75's
87 XJ Wagoneer 4.0L, 5" and 33's
93 XJ 4.0L (Dad's) 2" and 235/75's
97 TJ 4.0L (GF's), 4" and 33's
- Winners97TJ
- Learning to use the board
- Stroker Displacement: 4.7L - In Progress
I bought my SACHS clutch from O'Reilly's. My stock clutch measured at 1.5mm thinner than the new one after 150k miles! After seeing that, I was sold. It was only $130! Not only that, O'Reillys has a lifetime warranty on 'em. I'm not anticipating any issues, but if there are, I'll let ya know! Should have everything back in and running by next weekend.
