New to the forum. Got a 98 JGC 4.0 6 cyl with a bad eng. A friend is practically giving us a 94 cherokee w/ a 4.0. Need to know the details for swapping? is it an "even" swap? if not, what needs to be changed? ANY input/suggestions would be GREATLY appreciated.
94 4.0 to 98 4.0 eng swap???
ff18wife
- Vehicle Model: GC
Hi all,
- Missourian
Re: 94 4.0 to 98 4.0 eng swap???
These engine blocks vary greatly.
Several folks have attempted to make the swap but; the water pump is physically different, as are the motor mounts and your accessories mount differently. I would seek out another 4.0L from another similar year JGC or Wrangler same as your JGC date range.
XJ's and MJ's have the distinction of being alone to themselves in the 4.0L Jeep engine world.
- amcinstaller
- Vehicle Year: 1980
- Vehicle Make: AMC
- Vehicle Model: Spirit
i thought it was just the 99+ GCs that were different, and 98 and down were ok. i could be wrong tho.
- amcinstaller
- Vehicle Make: AMC
i was close. check here, in our beautiful FAQ section and it will tell you about the blocks, and anything else helpful
Blocks FAQ:
http://www.jeepstrokers.com/forum/viewt ... ?f=34&t=52
says there that 99/2000 and up are the problem.
Blocks FAQ:
ff18wife
- Vehicle Model: GC
Ok, then can someone please give me the correct year/make/vehicle model of what engines that would fit in my 98 JGC 2wd 4.0 6cyl.? That would help me tremendously in my search for another motor. Thanks!!!!
ff18wife
- Vehicle Model: GC
Here's another scenario... if I take the WHOLE engine/trans assembly from the 94 cherokee sport 4x4, would it bolt up and plug into my 98 jgc 2wd chassis and wiring harness? ps - don't care if the 4wd works, just trying to get it done.
- Missourian
It's the block everything else is the same.
One of those articles states that there is something different about the 1998 ZJ block. Don't know how true or what that is.
